high pressure - low flow rate pumps
I am looking for some type of cost effective fluid pump that can deliver 600 - 1000 PSI with relatively low flow rates (10 GPM+). The pump would need to have minimal pressure fluctuation (1% or less). I have thought of adapting a pressure washer for my application but it seems the flow rates generally max out at 4GPM. Any thoughts would be appreciated.
RE: high pressure - low flow rate pumps
http://www.catpumps.com/
Richard A. Cornelius, P.E.
WWW.amlinereast.com
