Setting variable bounds
I have been trying to find the solution to a nonlinear programming problem using the quadprog function. However, there is a boundary on my result so that it can only be from 0 to 1. The quadprog has limits on the function itself but not the variables in the function.
Simply, I just want to set bounds on a variable so that it can have only values from 0 to 1.
Can anyone help?
Katrina
