Foreshortened Dimensions
Is there some trick to creating these types of dimensions? Every time I try to drag the dimension from one view to another, I get a red circle with a line thru it.
Any info would be appreciated, as the SW help section was not much help.
BodyBagger
BodyBagger
RE: Foreshortened Dimensions
I am holding the SHIFT key.
Also, I have a section view that has a detail view. The detail view is where I would like to place the foreshortened diameter dimension. If I RMB the dimension I do not get those options of foreshortened dimensions.
I am including a pic
http://img
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP5.1 on WinXP SP2
SolidWorks 2007 SP2.1 on WinXP SP2
Star 4 you, thanks
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
