flattening a face in a drawing
I designing a boat that is to be made out of pieces of plywood. The faces of the object are disticinct sheets of wood. So there are no "humps" in the faces, only curving flat plates. I would like to take a face and unbend it so that it will sit on a flat plane. This I will then print and transfer to the plywood. A projection of the face on a plane will not work, because it will not be true size and shape. I would like to do something similar to flattening a sheetmetal part, but achieving the shape I have in sheet metal is a bit daunting to say the least.
RE: flattening a face in a drawing
Goo to http
