Generating Resolved Parts from Parametric Parts
I'm hoping someone here can help me. I am a designer of sheet metal stamping dies. The company I now work for is getting ready to start designing in Catia. I am making standard components in part catalogs, each part driven by design tables. The problem I am having is that I want to generate new part files for each component on a couple of the families so I can use the powercopies in them individually. There is a help topic "Generating Resolved Parts from Parametric Parts" that covers how to do it. The help file shows that you can create them by using a command prompt to run "CATCloGenerateResolvedParts.bat". I followed the instructions in the help file to the letter and I keep getting an error that it cant find the executable setcatenv. Does anyone here have any experience with doing this? Any help will be greatly appreciated.
RE: Generating Resolved Parts from Parametric Parts
The parts will be created here when you resolve the catalog.
I resolve the items that will be under heavy use. To resolve the catalog set the Resolution mode to Descriptions will be resolved under the Family definition menu.
Note - Do you have the PartNumber setup in the excel sheet?
Derek
