RF resitors 5 watt
RF resitors 5 watt
Can anyone help me with a source for in stock RF surface mount resistors, 5 watt, 50 ohm, up to about 4 Ghz, although 2 Ghz max may be ok too.
I found one at Florida RF Labs, called them to order, they sent me thru a rep RFMW and it takes 4 weeks (2/16 to 3/13)total to get stuff that's IN STOCK! I say .....grrrr!
I've found 2 watt versions that are made to order in 5 weeks at another company, but I'd appreciate a source of in stock hardware,
Kevin
Kevin
RE: RF resitors 5 watt
Peter
I ordered some from Bourn but was then asked to find some with simple solder tabs that aren't too thick for our layout. Bourn thru Mouser distributor had them in stock, now I need to search for some smaller profile ones with a tab.
Kevin
thanks to all for the help!
Kevin
