Mailmerge Excel to PDF
Is there a method or programme which can be used to mail merge information from excel to forms or fields in PDF?
I have a list of 50 landowners with various bits of information attached which has to be input into a standard PDF document and it seems rather heavy typing in each of 20 fields in 50 forms.
This is more a PDF question but couldn't find a forum for just adobe or PDF - is there one?
Cheers. Sean.
RE: Mailmerge Excel to PDF
If not then I am stuck because the PDF form is an existing one in PDF format. The transformation from PDF to Word would, I guess, loose the look of the form and therefore it would be unusable - standard government forms (Norwegian).
Thanks.
Cheers. Sean.
