Averaging data sets in an XY Scatter Plot
I have multiple sets of data of Force vs. Time (the times are different for each set of data), i would like to be able to average these 5 sets of data into a single line using excel. Basicly a running average between all the lines. Is this possible? or should i ask, what is the easiest way of doing this?
Thanks for any feedback!
-Ted
M.E.
-Ted
M.E.
RE: Averaging data sets in an XY Scatter Plot
Add each extra set to the chart using Chart | Add Data...
selecting add as new points and x-values in first column.
Add trendline to the result.
Alternately, stack all the data in two columns, and just plot it.
all of these lines
averaged together to get --> this average line
__________ Avg.would =
These are the lines that i have, I would like to generate another line that is the average of these 5 lines...not a straight line, one that averages each point from each of the five lines...so essentially it will look like the others, just at an average...like this
this is somethign that i doctored, does anyone know if Excel is capable of doing somethign like this automatically?
See other threads for advice on interpolation
Cheers
Greg Locock
In this way, your datapoints will all be at the same X values, and you can average them.
Cheers,
Joerd
