COUNT WITH IF
COUNT WITH IF
COUNT WITH IF
Suppose I have 3 columns of data. If the value in the first column  contains "F" and the value in the second column is "2006" then I want to add the number in the third column to a running total of the numbers in the thrid column that satisfied the criteria.
For example:
LF      2006      1           (True)
LR      2006      1           (False)
RF      2006      0           (True)
LF      2007      1           (False)
RF      2006      1           (True)
This should return 2.  (1+0+1)
Thank you for your help.
RE: COUNT WITH IF
insert  the following formula in column D
=IF(AND(B1=2006,RIGHT(A1,1)="F"),C1,0) and copy to the bottom of your range.  Sum this column and you get your answer.
RE: COUNT WITH IF
Thanks for that witchdoc. This works, but my example was simplified:
LF      2006      1        0        0
LR      2006      1        0        1
RF      2006      0        1        1
LF      2007      1        0        1
RF      2006      1        0        1
I have around 20 columns of data in the form of 1's and 0's and I wish to total each column according to the criteria. So here the total of column C should be 2, D 1 and E 2.
Your method would add an extra column of data for each existing column. Is there a way of achieving this with one line of code? I was trying COUNT with a nested IF.
RE: COUNT WITH IF
Have you tried the COUNTIF function?
     "...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
"I'm searching for the questions, so my answers will make sense." - Stephen Brust
RE: COUNT WITH IF
Yes i have, but without success.
RE: COUNT WITH IF
Try this one:
=SUM(IF(($B1:$B5=2006)*(RIGHT($A1:$A5,1)="F"),C1:C5,0)),
to be entered as an array formula (instead of <Enter> press Ctrl-Shift-Enter).
Cheers,
Joerd
RE: COUNT WITH IF
Thanks Joerd - problem solved.
RE: COUNT WITH IF
Hi David:
Based on your statement I have considered column A entries to contain F (and not limit it to be just the right most character). If your data posted is in cells A1:E5, then in a cell of column C, say cell C7, key in the following formula ...
=SUMPRODUCT(ISNUMBER(FIND("F",$A$1:$A$5,1))*($B$1:$B$5=2006)*(C$1:C$5=1))
then copy it to cells D7 through E7.
Yogi Anand, D.Eng, P.E.
Energy Efficient Building Network LLC
ANAND Enterprises LLC
http://www.energyefficientbuild.com
RE: COUNT WITH IF
Thanks Yogi.
