Can't select sphere to add assembly constraint
Hi.
I'm trying to add offset and surface constrains to a spherical part, but Catia doesn't allow me to select this part, or any other curved surfaces in the assembly.
I had this type of constrains added to the sphere earlier and there was no problem defining those. Then, I removed the existing constrains only to decide that I accually really did want them. But this, the second time, Catia just won't let me access curved surfaces.
What might cause this problem?
Pingen
Pingen
RE: Can't select sphere to add assembly constraint
The problem still remains though. Especially since the constraints become non-valid when I change the geometrical scale.
All other aspect of the scaling works perfect, none of the other constrains cause any problems.
Pingen
