Attributes in text leader?
Is there a simple way to display an attribute in the text leader box, such as "Part Name" etc?
RE: Attributes in text leader?
http://www
Surely there is a way to type a "wildcard" directly into the textbox (as you create it) that would reference a specific attribute associated with the object you have picked in the drawing?
Seems like there should be a way to easily do this. (not to mention avoiding the chance for some errors on certain tasks)
Went to 'options', set ballooning to use "part name" instead of "numbers". Then once you create the balloon, you can set the "frame" to be "none" so the circle disappears.
Shortfalls...the leader anchor is in the middle like a balloon instead of the end like a text leader, and you only get a single line text editor instead of multi-line like a leader. The upside is you can quickly call out parts, and it's associative.
I still wonder if there is a way to put the correct variable name directly into a text leader?
Bueller...?
