LA Megger Test
LA Megger Test
Is meggering a lightning arrestor really a good test to show if the LA is good or not?
I usually test the 8KV and above Las at 5Kv and if I am reading more than 1000MG then I assume its good reading; however I am told that intermediate La’s are resetting themselves and meggering a LA is not a true test to show if they are good or bad!
I appreciate any comment on this subject
RE: LA Megger Test
Hope this helps.
RE: LA Megger Test
By the way, I checked hubble website and there is nothing mentioned about the megger test for LA
RE: LA Megger Test
RE: LA Megger Test
Doble tests would show you watt's loss (basically, how good of an insulator the LA is), and a HiPot can be used to find the strike voltage, but the manufacturers seem to say that the factory tests are hardly ever reproducable in field conditions.
My two cents.
JB
