Cam Track on A Cone
Cam Track on A Cone
Cam Track on A Cone
I have been trying to create a cam track on a conical shape. 6.5 od x 6 long, with 10 degree draft.  Cam track is .5 x .5 spiral 90 degrees.
Can anybody help
RonFon@hiwaay.net
RE: Cam Track on A Cone
Need more inforamtion;
Does it "climb" up/along the cone and if so, what is the pitch of the spiral?
Is it parallel to then ends and if so, is the cutter (or cam follower) perpendicular to the taper or the main axis?
cheers
the ends (enterance and exit) are parallel to the axis, approx 3/4 radius to a 2 inch pitch spiral, the cutter is perpendicular to the taper, the cutter is 1/2 inch dia x 1/2 inch deep
