Bushing - electrical field
Good Morning
I´m drawing a bushing for 24 kV . The bushing consists of a rod ( made of metal),a tube(epoxy/glass fiber) and a flange (stainless steel).
I would to calculate the electrical field at the flange , to have an idea of the filed magnitude´and to define the right proportions for the rod and the tube .
I´m treating the problem like a cylindrical capacitor with two dielectrics : air and epoxy . The equipotential surfaces are then the rod (24kV) and the flange (0V).
The question is : how high can be the electrical field around the conductor ( between rod and tube )?In my opinion , the electrical strenght of the air should not be overcomed (3kV/mm ) .
Is this correct ?
To calculate the electrical field , i have do the following considerations :
1 - I have evaluated the capacitanche of each cylindrical capacitor
2 - The two capacitors are a series -> they have the same charge
3 - I have evaluated the voltage distribution between the two capacitors
4 - Field calculation
How high are the typical values of electrical field at the surface of the rod ( in air ) ?
Thank you a lot
Can you give me some suggestion ?
Is this correct ?
Thank you a lot
RE: Bushing - electrical field
I have to ask why you aren't just buying a bushing from one of the numerous manufacturers: a 24kV oil-air or air-air bushing is a commodity item and priced accordingly; exotic types are more expensive such as an oil - SF6 bushing for CGIT or an H2 - air bushing for a generator.
Have a look at some of the bushing manufacturers literature: for starters, ABB Micafil give some outline constructional details for their bushings, although the detail of the manufacturing process is necessarily commercially sensitive. http://www.micafil.ch/0320.html
Sometimes I only open my mouth to swap feet...
