Diagrams of Vintage Machining Equipment
Is anyone famliar with a web site that shows diagrams of vintage machining equipment(1940's thru 1970's)such as planars, surface grinders, vertical milling machines, lathes, screw machines.
RE: Diagrams of Vintage Machining Equipment
Try the antigue group at practicalmachinist.com
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Try getting Worksop Technology by Chapman . You can get all you need.
sometime ASME has published some articles in its regular magazine Mechanical Engineering - specially the 100 years anniversary issue etc. check with them:
www.asme.org
 others
www.sme.org
www.astme.org
Also try machine shop publications:
Blue book
Modern Machine shop etc.
Also you may want to try library books on History of Engineering
The best one I know is at www.lathes.co.uk. Enjoy !
