Mental Blank???
Mental Blank???
Hi All, I am having a problem trimming an extrusion that sits on an angled plane. I can explain with a simple example. A simple extrusion like a cylindrical bush and through that bush I have created a plane at a complex angle across it's diameter. On that plane I draw another extrusion say 3mm thick which extends outside the bush. How do I trim it back to the corrrect shape indide the bush so I can have the part made. Maybe a simple answer but have just gone blank. Maybe i am just an old guy with "old timers disease"!!!
RE: Mental Blank???
RE: Mental Blank???
Don't trim the bush back to the complex plane, use the second extrusion sketch to cut the material away, the way it would be done in the machine shop, using the Flip side to cut option.
RE: Mental Blank???
Thanks Steve
RE: Mental Blank???
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
RE: Mental Blank???
post file FAQ559-1177
RE: Mental Blank???
If an assy you can use the zero offset surface as a trim tool.
If a part, you could extrude-cut the ID from both ends of a solid bush, using the complex plane as the Up to surface and Offset from surface options to create the angled "web".
RE: Mental Blank???
http://
RE: Mental Blank???
RE: Mental Blank???
RE: Mental Blank???
Thankyou very much for your invaluable assistance here. That worked just fine. I will now have to get my head into the text and learn some more????
regrds
Steve
RE: Mental Blank???
I'm giving CBL a star on your behalf. In the future, click that link below a post that says "Thank _____ for this valuable post!". This gives the poster a "tipmaster" star, which is basically a vote for "Tipmaster of the week".
WAY TO GO, CBL!
RE: Mental Blank???
Jeff Mowry
