Does a Room with UPS require dedicated ventilation?
Does a room housing UPS equipment require dedicated exhaust system with hydrogen detection, emergency power and all, even if the batteries are sealed?
Is there any code that you know addressing this issue?
RE: Does a Room with UPS require dedicated ventilation?
Try posting your inquiry in the HVAC/R Engineering forum.
Good Luck
I would look in the electrical codes, which specifies the requirement governing battery banks.
Operation of the UPS of the Server
Atlas 06
There was a thread on this some time ago in the HVAC forum,
thread403-163633
B.E.
