2-wire and 3-wire instrumentation drawing
I am not sure in what forum to best ask this question.
I have 3 gas monitoring devices requiring 3-wire wiring scheme. As this is my first time doing this I am not sure what is the difference between a 2-wire scheme and 3-wire scheme. Does anyone know of any good online resources that shows a typical wiring diagram of this?
Thanks all.
RE: 2-wire and 3-wire instrumentation drawing
You really should find the manufacturer's wiring diagram, and not use a generic wiring diagram.
For generic 3 wire sensor/transmitters:
1)  DC power (typically 24Vdc, but not always)
2)  Signal output +
3)  common power supply return (-) and signal ground (-)
Dan
