Reduced bin pressure using geosynthetic reinforcement
We are looking to reduce lateral earth pressures (i.e., silo or bin pressures) resulting from backfill between a permanent soil nail wall and a multi-level building. Backfill dimensions are approximately 4 feet horizontal between the soil nail wall and structure and up to a max. height of approximately 22 feet. We have considered geofoam and other lightweight backfill, but want to consider a less expensive option. Does anybody have experience or references for reinforcing the backfill with geogrid or geotextile? And how to calculate what a reduction the reinforcement would have on the bin pressure? Backfill could be angular gravel.
RE: Reduced bin pressure using geosynthetic reinforcement
The designer will have to come up with a method of tying the soil nail wall and the MSE together - this is dependent on the termination detail of the nail and the denisty of nails in the structure.
http
There are two other papers on one of the author's website.
http://www
