Chemical pump stands?
My plant will be installing new chemical pumps and need a base for two W&T polymer pumps. Does anyone have information on companies that make stands or bases for pumps? I would like to raise them 10" to 12" inches off the floor. Any help would be appreciated.
RE: Chemical pump stands?
Locate Flowserve "Durco Mark 3 ANSI Chemical Process Pumps" Bullentin PS-10-13(E).
Corrosion resistant Mark 3 pre-engineered baseplates Type A thru E.
Also review the Flowserve Polyshield Polymer baseplate & foundation system.
Also can install concrete pedestal with corrosion resistant outer cover. In addition, may use appropriate corrosion material steel if raising only 10-12 inches.
