BOLT CIRCLE
BOLT CIRCLE
Is there an easy way to insert a bolt circle and maybe tie the dimension of the bolt circle to a bolt pattern?
Mechanical Engineer
Colmek Systems Engineering
Salt Lake City, UT
l l
0]lllll[0
l__l l__l
RE: BOLT CIRCLE
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
RE: BOLT CIRCLE
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
RE: BOLT CIRCLE
RE: BOLT CIRCLE
RE: BOLT CIRCLE
Dan
www.eltronresearch.com
RE: BOLT CIRCLE
RE: BOLT CIRCLE
Mechanical Engineer
Salt Lake City, UT
l l
0]lllll[0
l__l l__l
RE: BOLT CIRCLE
1. You can show the hole wizard sketch and dimension it. I always add the text "BCD" to the dimension.
2. You can also just create a circle sketch in the drawing and dimension in the same way.
3. Otherwise you can click on the hole callout and add the text and symbols to the the Dimension Text window.
Hope that helps.
Dan
RE: BOLT CIRCLE
When positioning the points on the HW sketch, use a construction circle, and add "BCD" to the diameter dimension. Then when using Insert > Model Items to place the dims, the BCD dimension will be seen. To complete the picture, RMB select the positioning sketch from the drawing view in the View Manager and select Show.
RE: BOLT CIRCLE
Mechanical Engineer
Salt Lake City, UT
l l
0]lllll[0
l__l l__l
RE: BOLT CIRCLE
Dan
RE: BOLT CIRCLE
