head pressure oil versus water in psi
Hello, I'm in need of a head pressure factor for 1' of water versus 1' of oil (say, 30 weight viscosity) . I have found a factor of .43 psi for 1' of water and oil is less dense than water so I know the figure should be less than .43 psi. Any help on this matter would be appreciated. I don't have a specific gravity on the oil either although I suspect it is around .90 (1.0 for water)Thanks, John
RE: head pressure oil versus water in psi
If s.g. is 0.9, the PSI/ft = 0.433 x 0.9 = 0.39
SG = 141.5 / (131.5+APIGravity)
so 30 degree API crude would be
SG = 141.5 / (131.5 + 30) = 0.876
Which makes the hydrostatic gradient:
Gradient = 0.43 * 0.876 = 0.377 psi/ft
Now what I don't know is if SAE 30 weight is similar to the API 30 degree crude (I typed the above before I realized that you had asked about 30 weight, not API grades and thought it might be useful to leave it).
David
SG=0.912
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
using SG 0.912
1 x 0.912 / 2.31 = 0.398 psi
It all depends on the accuracy required. When speaking of density of liquids (ρ) it would be better to state the temperature. For oils these are:
ρr, kg/m3, is the density at the reference temperature Tr, [K]
k is an exponent of temperature-density dependence (typically = 0.001/K)
A grade 50 base oil could also have a density of 888.7 kg/m3 at 10oC, while that for water would be 999.2 kg/m3 resulting in a ratio of 0.8894.
The ratio at 60oC, would be 0.8787.
BigInch
