What's your most desired enhancement?
If you could add one functionality to SolidWorks, what would you do? Maybe it's something that's incorporated in an add-in like SolidMap, but you'd like to see fully integrated. The majority of my work isn't creating designs (or if so, they usually aren't complex), but presenting them, at first with PhotoWorks, and now with Animator some. It really, really bothers me that Animator can't do transparency with PhotoWorks materials. Maybe if I understood the intricacies of the rendering process, there's some reason why it can't be done, but as it is, it just bothers me. What really gets under your skin?
RE: What's your most desired enhancement?
Animator is very unstable and quite a stubborn mule to use. You can get results if you do your planning right and quadruple the amount of time you'd otherwise expect it to take. It's funny that I can drag a component in my assembly and get a smooth drag of all dependent parts, but if I do the same in Animator, I get all sorts of errors with red key points.
So that's my vote. Overhaul Animator.
(This may well become a gripe-fest.)
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
mncad
I would like to see more on architecture layout/design.
Most of all, make the installation process easier.
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 02-10-07)
http://www.EsoxRepublic.com-SolidWorks API VB programming help
- Stop knee-jerking to the ACAD user base. If they haven't learned SWx by now.....they never will. Some people are just destined to stay in the 2D world. Win over customers by being the best-in-class not a product that kisses-up to a somewhat endless money-stream.....
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
1. make the current functions work like they are supposed to
2. fix the d*mn flexible assemblies, this is a CAD program, not a pretty still picture paint program.
3. drop photoworks and integrate its functions in SW
4. use direct3d for rendering, instead of opengl (ala max), this would make SW benefit from better drivers (more stable) and cheaper graphics cards (eg. more power for your cash).
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
-Making freeform not limited to a 4 sided face/srf.
-Surface knit diagnostics built into the command.
-Variable face/srf offset, Rough face offset.
-Elliptical fillet feature.
-Projecting curves normal to surface.
{o,o}
|)__)
"que?"
Work: Dell Precision 380-PENTIUM D 840 -PNY QUADRO FX3450 Drivers 77.56-2GB RAM--SW2007 SP1-RHINO 3.0 SP5
Play: Intel X6800 Core 2 Extreme - Asus P5W64 WS Pro i975X -2GB Corsair XMS-EVGA NV7900GTO(Mod. GTX Bios , FW93.71)-74GB Raptor-250GB WD Caviar
Chris
AutoCAD 06
Let's just say they gotta do something for 2008 or I'm not using this crap anymore...
The software is suffering from the Peter Principle big time. I used to love my job, now I can't stand getting up in the morning, and it's all to do with SW 2007 SUCKING.
I agree there should be no more new stuff added till existing stuff is fixed and 100% stable.
As for SW being "crap" ... I guess it all depends on how you use the program ... crap in = crap out. The majority of people frequenting this forum have few problems with SW.
As for SW, anything that can make the detailing (2d print) process faster is always great by me. That's the tedious part of the job. I'm not sure that switching from OpenGL would be so good because the OptisWorks RayTrace software I'm using w/in SW requires an OpenGL card.
Harold
SW2007 SP2.2 OPW2007 SP0.0
www.lumenflow.com
I agree with StefanHamminga about flexible assemblies, but I don't use them every day.
see: http://www.eng-tips.com/viewthread.cfm?qid=178339
Razberryjones, you might want to call in an order for Prozac.
Flores
It was not my intent to insinuate that you were a crappy user of SW, although after re-reading my post I can clearly see how that could easily be assumed.
Recalling some of your previous posts, you are having (have had) far more than the normal amount of problems with SW. As I've stated before, if you start a new thread listing the problems and system specs, there are many here who will be more than willing to offer advice and suggestions ... but PLEASE, omit the ranting SW bashing rhetoric.
It's all in the hardware and settings (and some user processes). If the correct procedures are followed, SW works awesome!
It's not like ACAD where it can be installed just about anywhere/anyhow.
Chris
AutoCAD 06
Heckler
o
_`\(,_
(_)/ (_)
Cheers.
I disagree with "Photoworks, as Animator" being useless.
I have used them to win major military programs. If you know how to use them (like anything else), you can do great things with them.
Rob, I hope you don't mind showing him this link ...
http://www.robrodriguez.com/
Chris
AutoCAD 06
I know there will be 101 naysayers to this .. too hard to code, other CAD doesn't, use dumb X_T format. etc, BUT I think a more realistic reason not to is ecconomics - Solidworks wants our subs and wants us ALL onto the latest release. And for those who say its impossible to do - heck, as an engineer thats what I do each day, making stuff that wasn't here yesterday, and what WAS regarded as impossible.
Not a SW issue. This represents the outer frontiers of geometry. There are PhD's working on this with little progress.
The mathematics for a true swept solid have not been invented. There are programs that do this by iteration and approximation (i.e. most CAM programs).
I saw few picked it here?
I looked at the site and it's only $695.
Did any one try it?
As it is, I can fake it with splines, but the fine control is simply not there for curve control. For instance, if I have several conic sections lined up to use as loft profiles, I have no way of making sure the resulting surface won't have dents or bumps in it with my spline method--with the conics, I can use similar tangency settings for each profile (from what I understand) to get a much more consistent surface.
Jeff Mowry
http://www.solidmap.com/webinar.html
http://www.solidmap.com/download%20trial.htm
Why not use the partial ellipse instead of splines? You don't have eccentricity control, but the root conic geometry is there.
I agree about using conics for loft sections when possible (i.e. no curvature inflections). Use of a conic absolutely prevents curvature inflection in any given 2D section.
I have actually recieved emails from SW showing the swept solids and the work they have done so far. It looks to me like they are fairly close to getting it. I'm not saying it will be exact, it doesn't need to be. Just something like a CAM package that would get me very close without having to create a ton of geometry that isn't creating the right geometry, just something that kind of sort of looks right but really isn't at all.
mncad
Hey, I'd also love to have swept solid geometry.
Jeff Mowry
As you know, A conic is the intersection of a plane and a cone http://en.wikipedia.org/wiki/Conic_section . The result can create a circle, ellipse, parabola, or hyperbola, which are easily sketched. The amplitude and tangency can be controlled with centerlines and dimensions. So if this can already be done in SW wouln't an enhancement request be like asking them to make it easier and pretty.
I don't really find to many things that I can't find a work around for in 2007. In the time I would gripe about something I usally can just push through and get it done. There are some oddities that do drive me nuts, but I haven't thought about bringing a gun to work (rasberry). I'm kind of a one man show with a bunch of EE's and software developers, which has its positives and negatives. When something comes out wrong and calls for ECO's there is no one to share the blame with.
I would request improvements in drawing layer properties and make working with layers more powerful.
I'm excited for what they are calling instant 3d, push and pull geometry as well as live section manipulation. This shows that things are going to have a more open architechture feel. I always think its funny when people say they don't use surfaces or do surfacing. Solids are surfaces, just packaged into macros, so i'm wondering if you can grab a face and drag it on a solid, and also do it if you did a delete face, made a surface body, and could still drag the face in or out. This would show that they are closing this percieved gap between surfaces and solids.
http://c
RFUS
So it's an enhancement that could be done with a work-around. However, flexibility and time-savings are what the software needs to be all about. I should be spending less time/thought on the software and more on my creation (according to [Jon Hirschtick?] during the SW 2007 release I went to).
Jeff Mowry
Jeff Mowry
Harold
www.lumenflow.com
I commonly use 5 axis cutting strategies where I post using RTCP (Rotation Tool Center Point). My tooling strategies are usually developed by keeping my tool normal to a ref surface while following a pattern or path. I can then apply a lead/lean to the path and it will all post out based on RTCP.
I have found I can emulate these cuts in solidworks by using curve driven patterns with an alignment method of tangent to curve and a face normal. I can send the profile of this cutter down the path with this same method. A lofted cut can then be created using these profiles with the path. Here is a very simple example of this in 2007.
http://www.box.net/public/g70qn3fa6a
For more complex stuff on models I'll use face curves, filled surfaces, and all kinds of guide curves, rotations on temp axix... but for the most part, curve dirvens with loft cuts make this somwhat possible.
RFUS
I agree its on the limits of computational geometery, but I think there are ways to make lofted cuts that emulate 5 axis cutting.
Tonight at the MSWUG (Maine SolidWorks User Group) someone said they wished that SW could show the foci of an ellipse. One of the VAR's said, well, we'll have to make and ER. This post jumped right into my mind. I piped in and said, just because solidworks doesn't give you the point doesn't men that you cant create it with two centerlines and a relation.
I was gonna do a write-up for the guy who asked the question, but with a quick search I found a VAR that did a writeup on it. There were two guys from here at the meeting and I don't think that they knew they had this writeup on finding the focus of an ellipse. scroll down a bit.
http
RFUS
But really, make it not crash and have stuff vanish as you are working on it.
rfus, that's good to know--basic geometry! (I've never needed the foci of ellipses before, but use them every time with parabolas.)
Jeff Mowry
Bradley
SolidWorks Professional x64 2007 SP2.2
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
NVIDIA Quadro FX 3400
Isn't that illegal?
Chris
AutoCAD 06
I thought about that when I was writing. Said to self, “No one here would think of such a thing. We are all professionals knowing more SolidWorks Speed.” Of course if we modeled our assemblies correctly I would not have a problem.
Bradley
Just kidding.
Not only do I want more speed from SW, I would like my PC to have more speed.
If SW were quicker, it wouldn't make a diff without a fast machine.
Chris
AutoCAD 06
To drag the cylinder the subassembly must be edited.
Fix the damn colors, it can be an absolute nightmare trying to find and remove colors in assemblies.
when i have an assembly with multiple configurations, and i put it in a drawing, then i add some scheets, in each sheet i put one configuration, but when i try to change the configurations SW does not chage at all .
What do you mean by "SW does not change at all"?
* configuration1 has small dimensions
* configuration2 has large dimensions
* configuration3 has other dimensions
(In the assembly are all configurations OK.)
Now I want one drawing, with on each sheet a different configuration.
So I did put my assembly in a drawing and added some scheets.
I ‘m able to get configuration1 on scheet 1.
Then I insert the assembly also in sheet2.
When I RMB-click on the drawing views in the drawing and choose an other configuration in the RMB-properties, SolidWorks does not change my views. On each sheet my dimensions stays the same as the first configuration, and the isometric view is all screwed up.
I'm only able to get one configuration right at the time.
Chris
AutoCAD 06
SW 2007 SP 2.2
Dell Inc. Precision WorkStation 670
2048 Megabytes Installed Memory
Windows XP PRO SP 2
Jeff Mowry
If not available yet, I would like the option to insert a part into an assy by selecting the face of the part I want to mate, then dragging into the assy onto the face to mate to.
Chris
AutoCAD 06
This is probably an outdated "best practices" intuitive thing I do more than a rational one.
Jeff Mowry
You can setup MateReference on each part you want to mate. We do that to all our custom build screws, washer, and nuts because we were not smart enough to use ToolBox correctly.
Bradley
Now I know many people will just say "but you can just use cosmetic threads". Sure, cosmetic threads are quick, easy, and don't hog resources, but there are plenty of times when you need the real thread geometry in the model.
SW07-SP3
What I would like to see is no one can take ownership with getting a new copy from PDM at time of taking ownership.
Bradley
SolidWorks Professional x64 2007 SP3.0
Virtual memory 12577 MB
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-13-07)
We also have “Set filesystem read-only attribute if not owner”.
The warning does show up about the file is older that the one in PDM. The users still just overwrite the file.
Bradley
Chris
AutoCAD 06
SW07-SP3
They have been trained over and over and over. We are not allowed to slap the workers anymore. Not like the old days, when we could fire employees easier.
Bradley
Management backed me 100%.
Chris
AutoCAD 06
