piles
piles
Hi, question from a C/P driller, so appologies if it is worded wrong!.
Trying to resolve an argument with engineer about depth of bore hole drilled with Pilcon rig. At 35mtrs the weight of the casing alone (150mm) is close to the maximum single line pull of the rig. I know its hard to say without looking at samples/logs, if the casing weighs 1500kgs, due to the skin friction on the casing, appprox how much extra in Kgs has the rig got to lift to pull casing out?
The strata is mixture of loose/soft wet sand/silt.
Regards,weight
JD
Regards,weight
JD
RE: piles
