Issues changing the solid tree
I am trying to change the trim line of a stamping component. I order to make the change; I have to create a pocket. I would like the pocket to be created inside of the "assembly" boolen operation, under a body, to be able to mirror the pocket later. When I try to create the sketch for the pocket, ones each line or curve is created suddenly disappears and I cannot see the last feature created, but the sketch is shown in the solid tree as something that has been already created.
Would you please, let me know how I can make the sketch visible to be able to constrain it and do the change.
Thank you.
Rob
Thank you.
Rob
RE: Issues changing the solid tree
No, I am not.
TOOLS + OPTIONS + INFRASTRUCTURE + PART INFRASTRUCTURE
in the DISPLAY tab:
turn OFF "Only the Current Operated Solid"
turn OFF "Only Current Body"
and just for fun,
turn ON "Geometry Located After The Current Feature"
