Go straight to Class Selection
I believe this started with NX3. When you try and blank,transform, or pretty much anything else that requires a class selection you get this little box now(NX3). Where as before you would straight to the class selection box. Is there anyway to get this back and skip that crappy little box. Thanks
RE: Go straight to Class Selection
John R. Baker, P.E.
Product 'Evangelist'
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
Paul Phillips
Specialty Engineered Automation
http://www.sea4ug.com
Paul Phillips
As for the change made in the mouse button actions in NX 4, this has been hashed out for months on the UGS BBS and the bottom line is that it's been wrong for "10 years" but now it's more logical and consistant. True, even BAD habits are hard to break, but...
John R. Baker, P.E.
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
What you need to do is add an environment variable, either to the System Profile, or if you're using a .bat file, there, or you can always add it to the 'ugii_env.dat'.
The variable is as follows:
NX_FORCE_CSD=1
I hope this helps.
John R. Baker, P.E.
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
