Plastic Part Design f/ Sealing
Does anyone know of a guide for designing plastic parts for sealed/sealing applications. In particular water resistance and water immersion.
I have a good handle on the design fundamentals of part design for sealing / gaskets etc but was wondering if there are any specific considerations for plastic parts.
Reason I ask is i am currently designing a plastic housing for a outdoor flow meter device. And am tossing up whether to utilise a face seal o-ring or alternatively a die-cut gasket as a copmression seal. Main concern with the latter is the potentially higher pre-load required to energise the seal over an o-ring. Although the o-ring may have a greater affect on the part design.
Any help much appreciated...Cheers Rich
RE: Plastic Part Design f/ Sealing
Consider also formed in place gaskets, e.g. rtv silicone, which require no preload.
Mike Halloran
Pembroke Pines, FL, USA
