First Operations Hot Water Coil Freeze Protection
Wondering if anyone knows of or has heard of First Company hot water coils freezing causing copper fins ruptures or bursts resulting in above ceiling air handler failure, not to mention, flooding. As of new year, units come standard with freezestat (used to be optional).
RE: First Operations Hot Water Coil Freeze Protection
I'll take a guess:
Are you cycling the fan? you may be running the fan continuously and may have gotten into stratification of cold air not mixing well with RA.
