Origin of the porosity in Steel casting
We have a problem on part casting, in CF38M. All the part have gaz defects.
Any solutions ?
I know that there is a lot of origins of this porosity, but how to find wich is the source of this defect.
This is a good paper from American Foundry Society. But how can i use these informations to avoid the porosity ?
http: //www.mode rncasting. com/archiv e/WebOnly/ 0905/WebOn ly0905.pdf
Stan
Any solutions ?
http:
Stan
RE: Origin of the porosity in Steel casting
I hope your mold and cores are ok and there is no entrapment or excess release of gases
wonderfull informations !!!
What can you say about our chemical composition
C : 0.07
Mn : 0.83
Si: 1.20
S: 0.005
P: 0.024
Ni : 10.2
Cr : 19.71
Mo : 2.39
Nb : 0.01
AL : 0.015
The casting is PUMP the weight is about 500 Kg. Chemical sand(ALPHASET)
I hope i answer your question.
Do you make thin walled pump impellers. What is the core material?
