Anyone runing a Spaceball with SW 64 bit?
I've just been told that 64 bit versions of SW07 aren't compatible with the 4000 or 5000 Spaceballs - has anyone else heard of this or shed any light?
RE: Anyone runing a Spaceball with SW 64 bit?
Try setting the Compatibility mode in properties of the spaceball exe to XP.
Bradley
SolidWorks Professional x64 2007 SP2.2
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
NVIDIA Quadro FX 3400
This is straight from tech support at 3Dconnexion:
We discontinued Serial (RS232) support on windows in Nov ’06.  This includes the SB4000 which is serial only and the Serial version of the SpaceBall 5000.  Also, we never supported any serial device on 64bit windows.  So, the USB SpaceBall 5000 is supported on 64bit, but not the serial version.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Don't know about those old models...but if you have to upgrade:
SpaceExplorer seems to work just fine on my XP64 box.  No stability issues even with enormous models.
Using the cute little SpaceNavigator with my 32bit laptop and it actually works great.  Perfect for anyone who doesn't actually program and use all the buttons on the SpaceExplorer...and way cheaper.
Ok, thanks for the info guys.
So is anyone using a USB Spaceball 5000 out there on 64bit SW?
I do. No problems here. I am using the latest driver from 3dconnexion.
Great, thanks for the replies.
