Revolve a Part without revolving the three main planes?
Good morning, I have a solid model, 1.563 rd., with four i/4 npt ports drill into the side of the part, 90 degrees apart. I need to revolve the part 90 degrees without moving the three main planes, so I can change the orientation of the main inlet port. Is any of that clear? Is there a way of doing it? Or do I just have to go back to scratch and start over? Thank you in advance for any assistance.
RE: Revolve a Part without revolving the three main planes?
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP5.1 on WinXP SP2
SolidWorks 2007 SP2.1 on WinXP SP2
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Colin
