NR13 Pressure Vessel Code
We are looking for somewone who understands the Brazilian NR13 codes for pressure vessels. In perticular which pressure vessels are exempt from NR13. For example; Our 5000 kW diesel driven generator packages contain seawater/freshwater heat exchangers, oil cooler, fuel oil filter all of which have a PV > 8. These are standard packages that have been installed onshore and offshore for decades. If you know of anyone who is an expert with NR13 we would very much to contact him/her.
RE: NR13 Pressure Vessel Code
Luiz
Brazil
luizhenrique_99@yahoo.com
In accordance with the NR-13 rules, all the pressure vessels where Pressure(kpa) x Volume (m3) > 8 must be included in the NR-13 pressure vessels classification.
If you need I have an English version.
Mancini
