HOW DO YOU CONVERT A V8 DRAWING TO A V7?
I am new to microstation and I am having trouble converting a microstation v8 drawing into a microstation v7 drawing. It started as an AutoCad drawing and I imported it into Version 8. Then I found where I could do a "save as" to save it as a version 7 drawing. Everytime I do, I get an error and then it creates the file, but it is empty and the file size is 0kb. Can someone please helpl me.
RE: HOW DO YOU CONVERT A V8 DRAWING TO A V7?
There is a perfectly functional Autocad forum on this site
TTFN
The ACAD forum won't really help.  If there is a dgn forum, that might do it.  ACAD can't/won't/whatever open anything but dwg.
Our firm has both, I only use ACAD.  I can tell you that we keep our cells (what ACAD folks call Blocks, I gather) carefully separated by V7 and V8, with strict directives not to open V7 files using V8.  I would guess, from that, that something happens to make them unusable in V7 again.
Engineering is the practice of the art of science - Steve
This should have been addressed at the Bentley:Microstation page. to do this you will need to use the saveas command and change the format to V7. Works for me.
Namdac
