Chamfer Dimensions
Chamfer Dimensions
Chamfer Dimensions
Is it possible to dimension an angel x distance chamfer with a leader note instead of an angle dimension and a distance dimension?
Dblcrona
RE: Chamfer Dimensions
Go to Tools > Options Document Properties > Detailing > Dimensions > Leaders and select Overide standard's leader disply then select the option of choice.
cheers
Select the dimension tool, then right click and select More Dimensions and select the Chamfer dimension tool.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP5.1 on WinXP SP2
SolidWorks 2007 SP2.1 on WinXP SP2
CorBlimeyLimey,
I tried that but when I select the feature to dimension it, it still shows up as two seperate dimensions.
Dblcrona
Oh ... you meant when using the Insert > Model Items method? I don't think you can.
cheers
