Importing / Exporting IGES
So export of IGES format models was requested of me.
Rather large, detailed models were converted using SE19.  I opened the IGES file afterward and everything worked ok (except for 20 minute processing time to open!).
The engineer recieved and looked at the file, with obvious errors.  Shapes/Bodies had changed very significantly.  The file was on the order of 37 Mb (unzipped).
So from what I have been reading, IGES is about the worst possible sharing format.  Step is my preferance, but IGES was the one requested.  From what I see IGES is more suited to surfaces and not solids.  I am not even aware of when you would be exporting just surfaces.
Anyways, Are there options I should select to insure optimum export of models?  Or should I suggest a different format all together?
Also, I've had bad luck importing IGES files in general.  A lot of errors/stitching necessary usually.
RE: Importing / Exporting IGES
I'd always push to go down the parasolid route, what is the end program/format that end user wishes?
Si
not sure, Nobody told me where its going.  It is going out to vendors to see if anyone can beat the current Vendor I would assume.
From what I've seen see if they'll accept Parasolid as SLemin says, else as you say step may be a little better.
Is the model a part or an assembly?
