Attaching symbols to cells in excel.
Hopefully someone has a quick answer for this question.
I have a table, its actually a symbol legend inserted into an AutoCAD drawing. Does anyone know if there is a way to actually attach the symbol picture to the cell?
In some cases I do not require a certain symbol to be shown so want to hide the row it's on, so when the WMF picture is attached to the cell the symbol picture will also be hidden.
Dan
RE: Attaching symbols to cells in excel.
Sorry about previous message - did not make much sense!
Bascially I just want to attach a picture to an indivdual cell in excel.  Can this be done?
Ther is a INSERT > PICTURE command, if that is what you mean.
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
Yes Insert > Picture is fine however I want the picture to be attached to a specific cell.  If I then want to manipulate that cell the picture moves with it.
When you RIGHT CLICK on the image, you can FORMAT the picture for various things including MOVE WITH CELL.
Borgunit - Spot on thanks for your time I appreciate it.
