Strain Gauges on Bolts
How do you attach a strain guage to measure the tension in a bolt thats part of a bolted connection? Photos would also be great!!
RE: Strain Gauges on Bolts
Here is a direct link to Strainsert's product:
http://www.strainsert.com/pages/load-bolts-studs-general.php
Look on this page for the link Force Sensing Bolt/Stud General Specification Wiring Diagrams - it has a nice image of the product.
Alternatively, you can use standard thin film gages, like those from Vishay:
http://www.vishay.com
You then need to drill a hole from the head to the shank.  I have seen nice diagonal holes that don't require any changes to the joint configuration.
Cory
