unhide all
unhide all
unhide all
I was wondering if there was an un hide all command. I went looking for one but never found one. I have an assembly that has alot of parts in it, I have three others working on this project with me and its a pain to go through all of the sub assemblies and parts to see whats hidden and not.
RE: unhide all
Unless I'm misunderstanding you, you can right click on the assembly icon at the very top of the tree and select "Show All".
Hope that helps.
RE: unhide all
RMB on the top assembly feature in the tree and click show with dependents.  This will show all parts in any sub assemblies that are resolved.  It will ignore any suppressed features.
Solidworks 2007 SP2.0
2GB Ram/3GB Switch
Quadro FX1300
P4 3.40GHz Duo XP Pro SP2.0
RE: unhide all
Try this: In the model tree of your assembly, right mouse click, the very top model, then pick show.
Bradley
SolidWorks Professional x64 2007 SP2.2
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
NVIDIA Quadro FX 3400
RE: unhide all
That kind of works. For some reason it does not show all (ie. purts within a subassemblly). I have tried this then rebuild and not all of the parts are showing back up.
RE: unhide all
thanks for all the help. I will write if I cant find any
thing.
RE: unhide all
You should not need any macros. Try this:
Click on the file name in the very top of the tree. Make sure it is highlighted. Then click on "Edit" in the very top of your window. In the list you will see "Show" or "Show with dependants". I always use the second. This way all hidden parts is the sub assemblies will become un- hidden
RE: unhide all
btcoutermash,
Thank you for showing us the “Show with dependants" button. A star for you.
Bradley
