Ducted Exhaust System
Does any one have information or experience for heat removal by ducting the exhaust (hot air only) of a few machines. Each machine has a cooling fan and the heat comes out of a grill on the side of the machine where I can collect the out flowing hot air. Is there a collecting system we can just buy. The hot air will be sent to out side the building. This air is clean and no filteration is needed.
RE: Ducted Exhaust System
If you are not in a cold climate then you'll have to buy an exhaust fan, design some exhaust ductwork, and get the thing installed. You still need a source of make-up air to replace the exhausted air.
Heat recovery is a good idea.
