animation view
animation view
animation view
Is there a way to control the speed of an animation of an exploded view?
RE: animation view
You should be able to drag the last key point back and forth to expand/contract "time" in your view.  It's the last point of your time-line--upper right corner.
(You're using Animator for this, right?)
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
RE: animation view
If you are using the Explode/Collapse animation module (rather than the full fledged Animator Module), then you cannot change the speed other than the "normal", "slow" and "fast" offered in the toolbar.
cheers
