Vapor recovery
Vapor recovery
We are looking at using a small compressor to evacuate a small chamber of hydrocarbons.
Essentially, we will have a chamber that we will draw into a vacuum. Then hydrocarbons, such as butane, is released into the chamber.
A compressor will evacuate the chamber, and store it in a tank for use later.
Any concerns I need to be aware of?
Charlie
www.facsco.com
RE: Vapor recovery
RE: Vapor recovery
Charlie
www.facsco.com
RE: Vapor recovery
At this level 'bout all I can suggest is to apply ye-ol PHA/HAZOP "what-ifs"...more pressure/temp./flow, less p/t/f, etc. (you probably know the drill).
RE: Vapor recovery
No, probably won't be considering an eductor.
Yeah, we know the drill, thanks though for throwing things out there.
Looking for things that we may overlook. It all seems so easy, but I'd like to head off possible problems at the pass.
There are a lot of safety officers already involved.
Charlie
www.facsco.com
RE: Vapor recovery
Types of units available. The smaller units say 15HP or so use sliding vane compressors, if a deep vacuum is requires, a liquid ring is called for. For all around use, the screw compressor is the one.
Spend money on good pressure sensors/transmitters on the suction if your system cannot take to much vacuum.
Teledyne makes O2 sensors for shutdown in case of a vacuum leak. I've seen more than 3% O2 in a gas, its not a problem.
RE: Vapor recovery
It's a small lab unit, I found a 1 HP compressor, it was hard to find.
Charlie
www.facsco.com
RE: Vapor recovery
Do you have all the necessary safety equipment. I would consider monitoring the tank stress/strain level as well as it will give you a warning about upcoming failures.
