Failed to Save Document !! What's this?
I've been working on an assembly for the last week, it is a combination of Top down and bottom up. Approx 40 parts. Approx 120 top level mates. I have had no problems until this morning all of a sudden I get a "Failed to Save Document" error. My PC was off over the weekend, I came in this morning booted and went to work. I saved the assembly several times this morning. The last thing I did was to insert another part and create a coincident mate. Then it failed to save. So I closed the assembly without saving, reopened it, repeated my steps and now it saves ok.
Did I do something to make this happen? Is there a SolidWorks bug? Although all seems well at the moment, I am concerned as to the stability of this assembly.
I am using Dell 670 2gb ram Xeon 3.8 Win XP Pro SP2 / SW 2007 SP2.0 and PDM Works and my Nvidia board drivers are certified.
Tom
Tom
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: Failed to Save Document !! What's this?
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Your assembly should be fine. The next time you open it, you may want to do a "save as" and save over the top just to be sure.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Otherwise JMirisola is correct its random, but 9 times out of 10 its a network causing the issue and its not about HDD space. Its about losing its connection with the TEMP file over the network.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
I must have something setup wrong. I expected that after I insert a toolbox part into my assembly and save the assembly to my local HD the tool box stuff does not save back to my network.
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Your only fix is to turn on Auto backup and save often.
www.scottjbaugh.com
FAQ731-376
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
SW07 SP2.0
Flores
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 02-10-07)
SW07 SP2.0
Flores
