Failed to open ?? problem, please help
Hello all, I have several important files that, for some reason, are now failing to open. It seems that everytime I create a new model (nx3), any old files will no longer open. Can anyone help me ? :(
-Rich
-Rich
RE: Failed to open ?? problem, please help
Justin Ackley
Designer
jackley@gmail.com
Check your load options.
Ben Loosli
Sr IS Technologist
L-3 Communications
Try seeing the syslog file or open a Unigraphics log file. It may give some clue of why you could not open it.
Opening a log file
1. Try opening the file
2. It will throw an error as you specified
3. Select Help-> Unigraphics log file
4. An information window will open. Check out the last 30 lines.
Opening a syslog file
3. Search *.syslog and open the latest syslog file in your machine.
Syslog file may be helpful when you run external ufunc programs without opening a unigraphics session.
Cheers
KarthikJ
Justin Ackley
Designer
jackley@gmail.com
