How to use LINK68--Thermal electric line in ANSYS
I have a resistor with applied DC current 3A for half an hour
The dimention of the resistor 1cm by 1cm square cylinder and the resistor is put in an enviroment which is 700 cesius
Resisity 0.5
Heat Conductivity 0.08
The properties of the resistor is all isotropic.
I would like to know the heat distribution (temperature distribution) at the end of the half an hour at 3A current
How to input all those constants in link68 in GUI?
I am a super beginner of ANSYS. You will be greatly appreciated for your help.
Thank you.
