trasformer rectifier assemblies
I want to build a 104 KVA  oil filled transformer rectifer assembly. Input is 480 VAC, 3 PH, Output is 1,705 ADC, 61 VDC. I have built  dry type transformer rectifier assemblies in the past. But I have never built it as an oil filled enclosure. Do you have a suggestion, how I should proceed.
RE: trasformer rectifier assemblies
Buy it from someone who understands the construction of oil filled transformers.  It's not something to experiment with.
