304 vs 316 for below waterline marine applications on boats
We are very cautiously investigating a switch from 316ss to 304ss on less critical below waterline marine hardware applications where some corrosion could be tolerated over a 10-20 year service life. The applications would mainly be skegs and rudder blades fabricated by welding waterjet cut plate. All the rudders would still have nautiloy or aquamet shafting only the plates are being considered for 304. Everything is bonded and fitted with sacrificial zinc.
Anyone made a first hand comparison between the two alloys in applications like this? Did the change shorten the usefull life of the parts or were they still being replaced at the same inteveral for other reasons?
The main reason for the switch is that 304 is available more consistently.
RE: 304 vs 316 for below waterline marine applications on boats
Corrosion Resistance in Marine Environments
http:
I see 304 as taking a risk for this application.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
How are the duplex alloys for welding? Do they still require low carbon welding rod? Do they behave predictably between physical test and FEA models?
-Eric
There are special weld rod grades for welding duplex-to-duplex. If you are welding duplex to austenitic stainless then 309L would be the preferred filler.
The Outokumpu web site (is difficult to navigate) has some great welding guides on it.
These grades have been used extensivly for structures and equipment. The properties are predictable.
Rust never sleeps
-Eric
