How to estimate the area of a delta wing
Hi ya,
Can any one help with any formula ( if there is one) with which the estimation of a delta wing area can be calculated. The only parameter known is aircraft weight.
RE: How to estimate the area of a delta wing
if you knew the wing loading (W/S) it'd be simple.
there may be typical values of wing loading, depending on the operation of the airplane (fighter, bomber, transport)
