NASCAR fuel scandal
NASCAR fuel scandal
The Toyota/Michael Waltrip Nascar Team has been penalized for using a fuel additive. NASCAR would not reveal what they found and there is lots of speculation and a few red herrings floating arround with the AP reporting that a person with knowledge of the investigation saying it was a property contained in jet fuel. There were also rumors that it was Sterno, or jellied alcohol that was rubbed inside the intake. The substance has also been reported as an oxygenate by NASCAR.
One of the more sophisticated theories is that methanol was added to the gasoline and reacted with the aluminium intake manifold and made the gel that was found.
Does anyone else have any ideas? I understand that rice has been ruled out as a suspect.
RE: NASCAR fuel scandal
Mike Halloran
Pembroke Pines, FL, USA
I've been around NASCAR quite a while, and have friends and a couple of relatives that work in that industry. Jellied alcohol (similar to Sterno fuel, but developed specifically for plate racing) is the most likely scenario. It is applied to the inside of the manifold. It can provide some additional oxygen, and bleeds slowly enough to be effective over a 2 lap qualifying run. Who did it, and why, is puzzling me.
The insiders speculation (according to a close friend of mine who works as an engineer for a big cup/busch/truck team) is that it was a jelled alcohol substance applied by a Toyota (TRD) person, possibly with knowledge of MWR personnel. In order to protect Toyota from major embarassment at their big debut, NASCAR and MWR have concocted the story about an "illegal" fuel additive that created a jelly like substance inside the intake manifold. This allows someone within MWR to take the blame, and shield Toyota from having to fall on it's sword (publically save face).
I have no idea if it's accurate. Until NASCAR comes forth and tells us ALL of the information, we may never know. Since they don't have a history of doing that, I'm not holding my breath waiting!
If any new information is published, it will show up here first:
www.jayski.com
Please understand that none of this stuff is new. It's been going on for as long as NASCAR has existed. Stretching the rulebook is all part of the sport. Smokey Yunick made a career of it. The old adage is: "It's not cheatin' if you don't get caught." Well, NASCAR is turning the screws, and more practitioners are getting caught.
-Tony Staples
www.tscombustion.com
That's been a typical view of NASCAR for years by a lot of folks who don't know the industry. However, as the dollars flowing into NASCAR have risen, so has the engineering effort. With such a restrictive rulebook, it takes a LOT of engineering talent to figure out how to make the car go just a LITTLE bit faster.
It's no different than any other form of racing. "Speed costs money; how fast can you afford to go?"
-Tony Staples
F1 guru P. V. Valkenburg in Racecar Magazine told of a WWII fuel additive that made gasoline thinner or runnier. Since it liked to disolve and then evaporate off, it had to be used fairly quickley. It was not used for power, it was used to transfer fuel faster. It was hidden in the dip stick tube of the overhead fueling tank. Turn the cap in a way to release it about the time the race starts, let it mix for a while, fill the car a few times, then it dissapears. Quite clever. Saved a few seconds on every fill. That's alot of time in F1.
"...fuel is somethin' ya just don't mess with. It's the big no no..." DW (last night on Nascar Live)
As to the article by VanValkenburg, I read about it in another publication and "sorta took it with a grain of salt". I'm not saying it is not possible, just, given the state of inspection of the fuel and fuel systems in F-1, I find it highly improbable.
Hemi.
Some of the finest (and highest payed) engineers are working in the field of motor racing...that definitely includes NASCAR!
Rod
A fuel system designer/builder I know from another forum recently designed a Holley carb circuit which produced 1% more horsepower and 1/2lb/hr lower fuel consumption at 185mph restrictor plate tracks. Given the restrictions involved and the years of dyno development already invested, it was considered impossible for a carb tweek to have that kind of effect. Innovation is always possible.
thnx, jv.
2.) Until Nascar comes forth with some real information, I will not even bother to worry about it. To my mind, Nascar looks like the idiot, not MW racing.
If I understand your post correctly, then I disagree. I really don't think MWR or toyota would test unleaded fuel in a qualifying run for the Daytona 500. Why would they do that?
Worth a read;
htt
I wonder if a gas blend could have been used that was basically a hydrocarbon but contained more energy as did the Formula One gas in the turbo era?
ht
Hmmmm, the plot (or intake manifold coating) thickens!
-Tony Staples
Benzene, toluene, and xylene are just three examples that come to mind.
None of these gel at anything like normal temperatures however.
Sorry, I was being flippant because at that point Nascar had refused to name exactly what the offensive material was.
They will be running Unleaded fuel this weekend, and I simply threw the two together.
I still have an issue with someone being called a cheater without the exact nature of the cheat being disclosed.
Mind you, I am not defending MWR, but I have seen the effects of rampant speculation on competitors.
I wasn't aware that they were running unleaded fuel this season at all. For some reason I was under the impression that this would be started next season.
It will be interesting to see the effects of the fuel change. As far as I know (I wasn't driving during the leaded fuel days), the main difference will be a reduction in comp. ratio and possibly less lubricity of the fuel. Any thoughts on this?
All this is totally PC, IMO. We gotta protect our children from all the leaded gasoline used in motorsports, you know.
Aside: A recent study...'soft sided lunch boxes'...of 60 tested, 20 failed because of excessive lead content. Some had as much as 1500ppm!!!
It's all PC...I'm not impressed. NASCAR is a 'sports team'(read that 'advertising medium') the way I look at it. I class them right along any other pro 'game'.
Why not just mandate 9.5:1 CR and use pump gas?
Rod
Some people have been using alcohol for quite a while, that is where rules allow.
The problem for NASCAR is multi-faceted:
1> They run a special Holley carb that is made specifically for NASCAR - it was supposed to be obsolete many years ago, but there are 1000's around now. Methanol eats aluminum so the carb, manifold and dump cans would all have to be specially coated.
2> Sunoco is a major series sponsor to promote sales at the gas stations. What benefit would there be for a non-consumer fuel?
3> Safety - methanol can blind you if it gets in your eyes, and splash is a danger during pitstops. It also burns clear so spotting a fire is almost impossible - just look at the problems Indy/Cart guys have with it and they have dedicated fueling rigs, not dump cans.
Perhaps with all the fuel cell research, some day there will be a racing series for hydrogen fueled cars.... I think I'll watch the Hindenburg 500 at home on TV.
Timing has an awful lot to do with the outcome of a rain dance.
Pumping oil is monster that rules the world - no doubt.But sport should be innovative not only in improving old technologies by getting one and another horse more from same restrictor plate,but also in other things.
Piston engine is primitive thing itself - way to much wasted heat and polution.I think if it has future - only in regard of biofuel.
I dont see any criminal in that situation with nascar being used alcohol.
Sport is always full of cheating, and this one wasnt the worse we remember.
Sorry for bad english.
Andrius
Rod
