conect node of element CIRCU124 with SOLID231
I have two element: the CIRCU124 and SOLID231.
I have a block de 50*50*13 cm, I apply the mesh, after I want apply the Voltage, but with the circuit using the element CIRCU124. How conect the node of CIRCU124 with nodes created in the block (this use SOLID231)?
RE: conect node of element CIRCU124 with SOLID231
Hi Jorand
first you have to coupling nodes in some area that you want then you have to choose a node (inside) and apply the voltage,  obviouly, in order to have a voltage in the block in other area of this block you have to apply a 0 voltage
I hope you can undestand my bad english
Lucky
