How to connect between metal pipe with PVC pipe?
Any people can enlight me about the connection between metal pipe with PVC pipe? Thanks a lot at advance.
RE: How to connect between metal pipe with PVC pipe?
What do you need to know?
have you tried a dresser coupling?
Depending on what you are trying to do, and the size and types of pipe, there are many options.  Flange, thread, grooved,rubber coupling, etc...
Stub ends can also be an option (you can use flanges of same material)
